Finally got the chance to sleep in my Trails West
Other than the poor heating, I'm fairly happy with my Trails West. There are some things that could be improved on and some things I'd change if I could but I guess most everything is that way.
I did order a larger furnace and plan to install it as soon as it arrives. I think it will greatly improve the heating problem.
What would Mike Holmes do?
This is meant as a tangent. Do it right.
Wouldn't it be great if somebody built a trailer with the intent of keeping it at 68F while the outside was -10F? AND if would have to do this for five days with the onboard fuel.
Use preformed 7'x8' sectional panels with all ducting and conduit installed. Trailer lengths would be in 8' lenghts depending on number of sleds to hauled.
Rolll up insulated door to isolate 1/2 of the trailer if desired.
Option the repair/occupied half and partitioned half with radiant heating for use when shore power is available.
It should be a gooseneck to provide easy hook up and best towing profile . Then finish it with axles-less independent suspension like the GMC motorhomes used to keep it low.
Sounds like a unit The Foose, Mike Holmes, and Airstream should build.
What else?
^ With the cost of that you could probably buy a 1/2 assed enclosed and sleep in hotels for the rest of your life lol
How much of the trailer are you using to sleep in? Maybe you could put up a curtain to divide the in used part off?
Sent from my DROID RAZR using Tapatalk
The furnace in my 28' b.p. is 30,000 BTUs. Suburban makes two furnaces that are larger, a 35,000 and 40,000 BTU. I'm thinking of going with one of them and then add a fourth duct that will just be vented through the cabinet. The first three will be hooked up to the existing ducts. The larger furnaces not only put out more heat, but their fans blow more air.
The larger furnaces have the same dimensions as my 30,000 btu unit and I think after I sell my old one, I'm only looking at $300 to $400 difference.
Did you end putting a larger 35 or 40k furnace in? I’d really like to have heat towards the rear of the trailer in mine. A couple powered ceiling vents could be cool too.
