So, after trying countless springs, weights and helix's i finally got my Axys to 41 MPH track speed.
He's what i have done to achieve this.
2016 Axys with a Camso 174, 2.8. with Avid 3" pitch drivers. The track is not as tight as Polaris specs but still got good tenstion on it. 48 hr's on the motor and 780 miles. Compression is right at 122 psi per cylinder.
I put the Pro RMK gears on for a cheap gear down.
Jaws pipe and MBRP Trail can.
Stright 40 helix with Black/Purple spring (160-240) with 2 derlin washers.
10-64 weights with a Pro Rmk spring. (140-330) and 2 thrust washers.
Shellbourne fuel additive with Shell 91 with no ethonal and in no ethonal mode.
8500-8550 RPM with 41mph track speed
I ride at 6000-6500 feet.
The sled just rips. I had a few guys ask what turbo i was running. opened the side panel and they were shocked. If your running a smaller track you will need to use 10-66 weights.
The Shellbourne additive made a huge difference and was necessary to get over the 40 mph wall. Sled runs almost 10-11 degrees cooler and helps a lot with the Jaws pipe. The sled normally runs at 128-129 degrees, now it runs at 117-119. I cant wait to try there oil as it is supposed to work with the fuel additive. But i have a bunch of GOLD VES that i need to use up first.
Im not sure if the cooler running temps is allowing the ECU to add timing, but the motor makes a sound 8500 that is hard to describe. It just sounds so on the pipe... if that makes any sense.
