T
Theron
If you do get a Nytro, there a few must do's. Pre-filter material to cover the two large vents in the sidepanels and the two openings in the cowl(can buy it in an 18" square at CC for $35). Powermadd pivot adapter and riser(stock riser sucks), Snow Eliminators(stock boards don't evacuate snow), and if you're heavy(over 200 lbs) you'll want the 2100nm Apex torsion springs.
You will probably spend roughly the same amount of cash on acessories for any sled. None of them come with everything they need. Dont forget your safety gear. You might be able to get that into the deal. Beacon, shovel, probe, etc... Check out the "whats in your pack thread". Good point to bring up.
