The 141 powerclaw is also a good, light track, comes in 2.25" and 2.6" versions. We have one of those, cut down to ~1.75" on one of our 570 fans.
They also have a 141 Cobra 1.6", that comes in at 41 lbs.
The O.P. is planning on running the Cobra 141" X 1.6" on his build.....
Is that the stock steering Collum from the 440 I seen in that picture?Here is some progress.
1 Made a template that has common locating holes in it from both the right and the left side of the chassis. This allowed me to lay out the shaft placement for both sides on one plate. Transfer punched the holes to the pto side, the belt drive side, and the shaft bearing holder plates that will attach to the sled.
2 Cut out new hole for drive shaft to slide thru when installing track.
3 Drive shaft installed. I could not believe the fixed bearing placement was only .055" from being in the right place. I found some Polaris bottom sprocket chain case shim washers that were the right thickness and shimmed the bearing to prevent side loading it. The drive shaft is from a fusion trail sled but I believe it is also the same as a 08-10 RMK. I was going to use a hex shaft and shorten it but this one is lighter and the only mod will be the shim to move bearing placement. I also have a 13 PRO shaft that I am thinking about using because it is even lighter than the hydro formed one but it will require a custom spacer be made, as it is not as wide.
4 Driven side bearing plate installed. I am also working on some ideas to get grease into this bearing, and make a new pick up for the drive shaft to send a spedo signal to the gage that came with the sled. I think it just needs a single magnet on the shaft and a pick up mounted to count the shaft revolutions.
5 Belt drive side with brake caliper in place. Still have more to do on the belt drive plate. Some of the bolt holes will need to get counter sunk for rotor clearance.
6 Still working on the new plate for the driven clutch side jack shaft bearing.
Sent from my SM-G950U using Tapatalk
How did it fit up? What did u use for the rest of the steering ?Yes that is the steering shaft from the 440.
Some day I need to get back to this and finish it.
I hope to get back to this soon.
Any luck coming up with a plan for the driveshaft?
My latest variation of my 440 fanner came in at 375lbs. I'm gathering parts to put a 570 in her.....the 440 spins the 141x2.25 track really well however he extra HP will be ideal I believe. Need to wait on Aaen for another round of pipes....I missed out on this years batch he made for a bunch of guys racing. Maybe next winter the 570 will finally be in its new home.
As is tho, it's an amazing machine. It's always WFO and not one person that rides it comes off it with less than a huge grin.
Can't wait to see what you did for the single cylinder Pro!
If you can find one, the pro x 440's were rated pretty high as far as fan HP goes. From what I've read the engines in the 02s and 03s were a bit hard to get running right, arguably not very reliable, but i've seen numbers online stating they could put out upwards of 75hp on them.
