I used the oil bottle and it fell off and went into my clutch.
I did use the velcro that came with it. That may have been the problem.
I ended up stashing it in the tool bag.
We zip tie them to the wire harness that runs along the over structure.
Can't remember where I mounted the PCV but it easily allowed the needed hard wire connection that you need to do to change things at home.
I do remember, after I mounted the new Boony box on the handlebars with a capture button to eliminate any guess work on where I wanted my changes to the fuel, that I was much happier able to test my changes right away.
If you make a clutching change or get out on a sunny spring day where you can tan on the stops lol, it`s nice to be able to "drop the needles" or "change the jets" like the old days. Just cleaner, quicker, and less work.
I'm a Boony Box fan again with the new TPS interface and 13 rpm program.
