Well, we're making progress on the old girl-finished pulling the bulkhead apart , cleaned up the old glue and re assembled the coolers and bottom panel with fresh adhesive in preparation for the tunnel sides.
a little scraping and a heat gun removes the adhesive easily.
After paying attention for a change...it appears that this adhesive releases easily at about 150 degrees-a light prying force is all it takes to know if it has released or not.
here are the removed sections ready to clean and assemble.
Bottom plate and cooler after fresh adhesive and assembly:
The final tunnel sides are fitted, drilled and ready to assemble finally! we are finishing the pto side extrusion and will be assembling the tunnel over the coming weekend.
In the meantime....we've finished designing and building our Billet 6 mount Pro motor plate--this will be the answer for all of you turbo and big bore guys when the stock mounting system has problems...
And we've gotten a good start to the turbo system-we are working with HM turbos again and using Shanes proven components including the liquid intercooler system he pioneered several years ago. The Pro RMK won't have a bulkhead cooler to utilize this system but we have a way around that for you also! There will be a kit available from us and HM turbos to install the Rush bulkhead cooler into your Pro RMK if you want the benefits of rock solid consistent charge temps in all conditions.
motor mounted up and ready for turbo plumbing fab work to begin!
the Pro mounts the motor way lower than the IQ so they use angled boots to keep the throttle bodies out of the bulkhead.
tons of room in this chassis! the intercooler will hang from the hoop here...
Heres the pipe routing-fit like a glove even with the non-stock motor configuration
the internal stinger design leaves us lots of room for the turbo since the pipe is significantly shorter without the stinger hanging out...
most of you probably haven't seen this yet but this is what we do to keep pipes on turbos in one piece-its a custom made stainless flex bellows that we use to get rid of the unreliable and poor pipe to manifold sealing characteristics of most all current two stroke turbos-our design allows the pipe to go through its contortions due to heat cycles and still maintain a 100% pressure seal to drive your turbo. Allowing the pipe to "float" also alleviates the stresses on the pipe which helps keep the cracking issues away. we use stainless flanges to secure and seal the joint so no more broken spring issues and assembly is quick and easy with no bleeding!
turbine flange is fabbed and welded up- silencer is next and there is a ton of room for it!
nice short charge tube run to the intercooler...
Also got the rad new Avid drivers mounted up on the shaft
Sorry to post this all at once but we've gotten busier than ever and I'm losing my computer play time! I'll have more to post next week!
curt
