Since there are a few unknowns with the new Pro RMK and the shops turbo 800 Dragon has been sold we've decided to jump in and get a head start on our own version of a Pro RMK.
We started by purchasing a Rush from Minnesota and with the help of a couple SW friends it is now in the shop and torn down.
This first post is mainly teardown stuff but there are some good pics of the chassis to checkout and if you've ridden and looked at the new Pro Rmks you'll see some of the differences between these chassis.
Along the way, we will detail the way we look at curing track clearance and approach angle issues and mod motor mounting issues in the hopes that some of what we learn can be applied to the 2011 RMK as well.
We plan to sell the 600 that came in this sled and install an '08-'10 vintage CFI 700 or 800 along with a turbo while the techies sort out the new electronics in the 2011s!
There will be a bunch of hurdles to cross along the way as usual and we'll do our best to keep you in the loop of what we are thinking.
The donor sled: a slightly used Rush purchased from a friendly cross country racer in Minnesota
Mag side view after partial tear-down:
Pto side view after partial teardown:
Front view after partial teardown:
Another layer of bodywork gone now...you can really begin to see how much room is really in one of these bulkheads. I'm impressed with the cleanliness of the bulkhead assembly, the triangulation is smartly done and I can see that the components of the modular bulkhead would be very easy to replace if necessary.
Good thing all of this is going in the swap-meet...man what a hideous conglomeration!
Well, we've just removed 80 lbs from our project (yes, 80 lbs right on the money as you see it!)
If any of you have torn down an IQ RMK, this shot should tell you how much further down the motor is mounted in the Pro chassis!
OK, now we are getting some where! harness and bars have been removed
Motors out (and for sale or trade!) and you can really see how much room there is to work with. The layout is nice and simple...
Now, honestly at this point we could just build a new cooler, tail section and just put 'er back together but we don't work that way...gotta make it cooler than that!
Here's one of the big hurdles with this(Rush) chassis: with a 1.25" track and 8t 2.86 drivers we only have 1.25" of clearance! well that will just have to be addressed now won't it? Drop and roll here we come!
Lots of triangulation goodness going on here:
Not to sure how well this motor mounting arrangement will handle 200 or more h.p....I think we'll be addressing that as well in this build.
Here are the rest of the motor mounts:
Here is another area significantly different than the Pro RMK chassis. The Rush has a more traditional rider/steering location so we'll be looking into adapting the RMK parts onto this sled as they become available.
Pile-o-parts...just what we need, more stuff to trip over through the summer!
We'll be pulling the tunnel off next and development of the new tunnel will begin...we'll keep you posted as things move along!
- We intend to end up with a 162-174ish 2.5" track and are still pondering on the skidframe.
- We will be building a carbon fiber tunnel/running board set up for it and plan to use 163 RMK coolers.
- We have also already begun development of some unique carbon fiber body parts to address a few of the issues we already see.
