A shout out to Fastrax for doing the Power Addiction 12.5 head on my 11' pro. It was the best mod I could have done, pulls like crazy now. And a shout to Power Addiction for providing the head.
Thanks,
MM
Thanks,
MM
Did you have to add any clutch weight?
I had zero miles on my 12 and reused all orings, also put on a PA head and Carls clutch kit and it runs excellent except too many rrrrs , I want to change out the 60 weights to 62s per F-bomb . Called Chris at carls and he gave me a real song and dance that it is not overreving cause the rev limiter is not until 8900 or so ,hahaha I call B s,,, this sled definitely runs better at 7950- 8000. Needless to say he wuold not exchange the weights .Poor custumer service if you ask me!!!great thread... great info..
have a PA head coming on its way.. hope to have it put on this weekend.
did u guys put all new orings and seals on when u put the new head on??
90% of the time, you can re-use the head o-rings. Clean and inspect for cracks, evidence of pinching etc. I like to give light coat of grease on them so they don't "roll" when putting the head on . The grease also acts as a primer (to a lesser degree). I have re-used the same o-rings up to 4-5 times on head swaps.
Many times, folks can pinch the o-ring(s) when installing the head. Lining up the holes will require slight movement of the head and the grease lets the head slide and not pick up the o-ring out of the groove and pinch it. Pinching results in coolant leaking inside, outside or both of the motor. Burning coolant in the cylinder too long can take out bearings. (don't ask me how I know about rod bearings being taken out by burning coolant....)
Hey MM... Must be nice to ride a high performance machine... I would just like to put the first mile on my sled in the garage!!!
