Do you know the napa part number, mine reads right sometimes at idle then goes blank at wot and sometimes reads 10.# at idle.
Really....$35 bucks? That is good to hear. I have never found them for less than $65.If its reading 16 through all throttle positions it maybe screwed up, check plugs, pipe and piston wash to make sure you aren't to lean. You can buy a replacement afr probe at Napa Auto for $35, worth a shot. If you have added the max fuel on the box you can get more by raising fuel pressure....but you should have already seen the afr come down.
i have a new afr aem gauge , it reads 16+ all day, i added fuel on my attuide box, no change, did i get a dud or do i have a problem. the turbo kit is a ovs pg on a m8 11, fuel pressure is 38 and elevation is 4000-6000.
how about a digital gauge that you can read up to five things? what do you guys think of that?
so do we keep green and yellow at 1 because its close to stock settings and theres no boost down that low?
