It should never lose prime, if you don't have any air in your coolant lines. The deal with a snowmachine is that with the heat exchanger the way it is, and where you need to run hoses, its a little harder to eliminate the air from the lines when its sitting in your garage. WHen your up on the hill, and you have a turbo, and you have a water air IC, you'll probably have the thing vertical before too long and it lets all the air flush through. Once the air hits the pump, the pump stops pumping.
If you plumb your stuff correctly it shouldent be an issue. I'm going to re-run everything on mine with this in mind and I think it should no longer be an issue. I've pretty much got it mounted in the worst place possible right now.
Here's two pump options:
http://www.frozenboost.com/product_...=1000&osCsid=e64a8b3599fafa748b87337f3f2fe4c9
http://www.frozenboost.com/product_...=1001&osCsid=e64a8b3599fafa748b87337f3f2fe4c9
Both of these are centrifugal impeller pumps. They are the only way you'll get close to 500 gallons per hour pumping while staying around 2 amps. (the bosch is less flow and higher amps)
Anyway, you gotta keep in my this was my first crack at doing this and I didn't think the pump would be so sensitive to air. I am going to re-run everything and it should be pull and go after that. I'm sure you could do it right the first time and get it set up nice.
I will say that it is AMAZING the difference that the cooler makes. You can definitely feel it on the top end, but the real advantage is the low / mid RPM response. It feels crisp, clean and has lots of power right out of the hole. I don't think you would get the same results using engine coolant. The engine has a thermostat that opens and closes, and your return coolant temp is very sensitive to how much snow you have going over your heat exchangers. I say this, but I've NEVER tried it and i've been proven wrong before! Just doesnt make a lot of sense to me and welding up an extra heat exchanger was not too big of a deal.
If you ride an 07-08 M8, OR you live near Utah, i'd love to help you weld sometime together for your application. I definitely think i've got the M8 solution figured out. Coolant lines come up right through the front of the tunnel by the ignition coils. Shoot, if you've got an M8, I'll just sell you a whole water IC kit!
