F/S XCR 800 engine fitted for IQR chassis
Testing the waters here, contemplating selling my IQR/XCR 800 Tripple to install a less powerful engine that is PERC compatible. Would consider partial trade for Polaris 600, 727, 797 Smallblock engines. Engine dyno'd at LRM in Colfax WI, dyno sheets available. Not a lot of time on this engine, but the the times I've ridden it, its scary fast.
Engine is an 2001 Polaris XCR 800
Flannery cylinder and case porting
Crank was redone, all new Polaris bearings
New Polaris pistons/rings, Wiseco Prolite wristpins
All Polaris gaskets, seals, o-rings were used
Rebuilt waterpump
Hot seat 14:1 heads and Hot seat 12:1 heads
VF3 reeds
Indydan reflash on CDI
LRM custom fitted pipes with ceramic coating, 8500-8700 RPM
LRM custom motor mounts
LRM modified Steering hoop
New carb boots
Custom Steering post
38mm rack carbs, all new floats, seals, gaskets, have the black slides waiting to go in
Engine runs on Pump 91 above 5,000', I have pump gas sea level domes also
New Poalris primary clutch (Indydan balanced)
Custom fabricated airbox, oil tank and CDI mount
PSI Billet Thermostat
Many spare parts included, 2 waterpumps, CDI, coils, spare primary clutch, gaskets, spare VF3 reed cage, etc.
Serious inquires only
A few pictures:
Rebuilt waterpump
VF3 reeds
New carb boots
A few pictures:
