f/s... m6/7 to 800 complete motor and electrical...stock cat 800 pistons
As title says... complete motor for your 6 or 700 laydown. trued and welded crank, only 200 miles at the most on it. speedwerx head setup for pump gas above 6k and a splash of race below that. jeff at dakota performance has the engine now and says its in great shape... he took some compression out of the heads so it can run on pump. hanson racing did the big bore, its just like everyone elses out there running the stock 800 kits, pull the rope and go!
complete motor, crank and cases, throttle bodies, ecu, wiring harness if needed, valves, servo motor... EVERYTHING you need for only $2250! all you need extra is a fuel controller and stock pipe will work or find a stock 800 pipe or aftermarket for best results! motor runs great.
thats a steal... i'll even toss in a spare piston, new in the box.
selling because i dropped a 1000 in the chassis and put a turbo on it.
$2250... wont last long at that price, seeing top end kits bringing 1500, ecu's bringing 4-500... and you'll have a complete spare motor for backup or sell!
gotta be around 155-160, like most the others out there... with twins i spose 160 or a lil over.
i have a verbal that its sold... if not i will let you guys that have pm'd me know.
