EZ-Ryde review
hi all. back when i was looking for info on the ez-ryde i didn't find much, so now that i've got a whole bunch of riding time on mine, i figured that i would try to help out the next guy.
i installed this setup to replace the stock skid on my 05 m7 with torque arm relocation and 2 wheel kit.
my ez-ryde is the one that is good for all track lengths from 151-155
on the bathroom scale, the ez-ryde was 8lbs lighter than stock skid. a little less than claimed for the m7, but this ez-ryde had a set of scratchers on it (+lbs), and the stock skid had the 2 wheel kit (-lbs).
installation was a piece of cake. the template supplied made hole layout easy. the skid bolted into place easier than the stock skid. hardest part was working my rivet gun.
1st impressions of the ride was that trail bumps were much less noticeable. very very smooth. but its not a magic carpet. it will still leave the ground if you hit stuff hard enough, but the sled wont pull the nose up, or buck the rear end at all. if you bounce off the bumps, the sled stays perfectly parallel with the ground. very very easy to maintain control and you rarely have to take your thumb off the throttle to hold your line. this is extremely helpful in the middle of a steep climb!!!
i did find that the balance points of the sled had changed a bit. i found that i had to change my body position to throw it around. took me a while to find the sweet spots, but now i find that boondocking and sidehilling is much improved over stock.
the claims that ez-ryde makes about less snow retention in the skid are 100% true. this is dependant on the snow conditions of course, sticky snow being the worst. in sticky snow, my skid stays totally clean and my suspension is still working. everyone else i ride with is carting around a ton of extra weight, and their suspension has zero travel as it slams into the huge ice ball underneath them. check out my attached pics. they look just like the ones from the ez-ryde website!
on the downside, you do lose some of the fun factor of the stock skid. catwalking off of little bumps or the tops of hills is now nearly impossible. it keeps the front end down almost too well. maybe you could get this back if you adjust the preload enough.
also, jumping is affected a bit. i find it to be an improvement on big jumps, as you have more control as you leave the lip, and landings are a bit softer. but its much harder to get the sled to leave the ground on little random bumps that you find here and there. i find that i have to hit stuff much faster. again, playing with the settings might help this out if that is important to you.
not sure how it stacks up to the new skids cat is using, but if the price tag doesn't scare you off, i doubt it will disappoint you.
the design of the ez-ryde, and the fact that it is powdercoated, doesn't allow for snow to get trapped as easily as most stock skids. when you look at a sled with an ez-ryde, there is a lot more of an open void inside the track compared to a stock skid. since i've been paying attention to it now, it seems that the stock xp's are the worst at trapping snow, and the stock cats are probably best at clearing trapped snow. but nothing comes close to the ez-ryde.
note: i havn't been able to compare any of the features or the characteristics to the timbersled stuff.
Your description is spot on with what I've seen. It is very good at keeping cleared out, except mine doesn't evacuate snow as nicely as your pics show
I think one other main difference is, I run an older 162 EZ and the geometry of it dictates I run a much tighter track.
It also takes a fair amount more maintenance that a stock suspension. By that I mean all of the small bushings and wear parts need to be addressed annually. The suspension works so well that I think these parts get a huge workout and wearout. The main components are tuff and bullet proof and require nothing.
For the handling and ride, I gladly will replace the little items every year.
Now I don't know if I want one.
I LOVE braapin' off of little bumps and jumps I find out there in the wild.
Thats half the fun!!
i hear ya. this is the only bitter-sweetness about it. i really miss all the little jumps.... but it sure is nice landing the bigger ones now. and the trail ride home isn't nearly as painful. actually, i find myself much more comfortable hitting all the hip jumps i find on the sides of the trails now. one door closes and another opens.
I have one on my 08 m1000 153. I have rode nearly 4k miles in the two years I have had it. Love the skid. Everything Polemite wrote is spot on. In March of this year I had to replace some of the bushings and some of the idler wheel bearings in the small wheels. That's it and I bought the skid used. The guys at ez-ryde are great to deal with too.
I found on my Apex that if you change the front shock length it makes a huge diff you can plant the nose or make it a ski lift king 1 in made a huge diff my t apex would do a 100 Yard wheelie I shortened the front shock 1 inch and it was hard to pull skis off the ground.
How does it perform in deep, soft snow? Does it get on top of the snow pretty well? Can you lift the skis with throttle?
i changed my track to the power claw at the same time as i did the ez-ryde, so other than the snow clearing out of the skid, i couldn't give you an honest answer about how much improvement there was from the ez-ryde alone in the deep snow. but the snow clearing alone is a huge improvement to deep snow riding. i think i might have seen much better deep snow performance if i had gone to an attack 20 track rather than the power claw.
i can definitely tell you that i climb up on top of the soft stuff if i'm full throttle and going in a straight line. but i havnt seen ANY sled yet, including mine, that can STAY on top once the rider starts tossing the sled around, or climbing something.
i've addressed this already, but the answer is "yes, if you want". ultralord mentions it. playing with the settings can pretty much get you any sort of performance you are looking for. so it sounds like it could be done, but most likely at the cost of deep snow and hillclimbing performance.
