A
Arctic Thunder
As you all know the M1000's run really lean prior to the exhaust valve opening. It is hard to tune this out because the point of opening changes with elevation, temperature, throttle position, intake temps, etc.
So my question is if you installed a BDX delete kit or someone else's and installed the jumper would it eliminate the step in the ECU that is causing this lean spot?
Or can you get your ECU reprogrammed to eliminate this lean spot?
On a street bike, from what I understand, their is a pair of wire that need to be cut and spliced to bypass the emissions crap and avoid this lean condition.
Just trying to get around the AC standard program.
Any ideas.
Thunder
Any ideas.
Thunder
