A
AdrenalineAddict
I'm seeking knowledge about the exhaust valve relearn from those who understand the process.
Back story:
1) Finally discovered why my sled wouldn't run
2) Exhaust valve retaining bolt unscrewed itself from the valve.
3) Disassembled entire exhaust valve train, unhooked from servo, removed cable, cover, reinstalled valve and bolt, aligned valves, reassembled.
4) Took out for a test run today, runs great, no codes
Many have told me I now need an exhaust valve relearn. Why would I need a relearn if the sled was never powered up with anything disaasembled, there is no distance adjustment on the cable, couldn't lengthen or shorten the pull if you tried???
Back story:
