06 RMK 900 151"
I was riding the past weekend and started smelling burnt plastic, stopped and opened my hood to find my wire harness melted down to the wires. I had extra zip ties and remounted the harness to get off the mountain back to the truck. On the way back the temp sensor worked fine but no tach or speedo. No service engine light but the temp light would flicker on and off. I figured some of the components were grounding out or touching some of the other wires. I got home and re spliced all of the melted wires making sure that all connections were good. After repairing the wires and taking the sled out for a test ride the tach still reads 0 all of the time and the exhaust temp says error. The speedo works sometimes while riding but not always. The speedo will jump when I first start it, but then remains at zero. The sled seems to cut out a little at mid range throttle but runs fine at high rpms. It starts easy cold and is harder to start when warm/hot. I have a feeling that it could be multiple things. I have checked all of the wiring for loose or broken connections, but haven't found anything. I'm looking at getting a new harness, temp sensor, and TP sensor. Any help with diagnosis would be greatly appreciated.
