Excessive oil consumption!
T
theultrarider
Like most everyone else with a new pro, Last year my sled would get atleast 3 -4 tanks of fuel to a tank of oil. In other words, about a quart to 10 gal of fuel. This year immediately after my dealer did the oil line reroute, I now go through over 2 quarts to 10 gals!!! I questioned him as to wether or not they had turned up my oiler on me. He said they had not so I had them check it over since it was not leaking out anywhere. He found no reason for it to be using so much oil. Well, went for a ride on Friday burned better then a quart of oil to 5 gals of fuel.
I just got out of the garage and have found that my oiler is sticking wide open and will not return back to the idle position without "helping" it. Sticks totally wide open. Was running so much oil through it that it was plugging up the exhaust valve seleniod to where my exhaust valves would not open. I had to pull the lines and just plug them off to get full power/rpm out of it.
Now, do I drop this off at the same local dealer, Or drive 6 hours one way to a decent reliable shop? Either way, I'm gonna be screwed for the rest of the holidays. I have tried spraying both ends down with brake cleaner followed by wd-40 to try to get things to free up. It doest feel that tight, just slightly more than what the spring will pull back. Don't know at this point if it's a bad spring issue, bad pump (obviously pumps well) or what?
I hope this helps someone else out should your oil consumption suddenly go through the roof and/or your exhaust valves start sticking shut.
it still wont hang with mine..bwhahaha..course when you get the goddies on it..mines in the dust...
Ultra:
Take your ride back to the same dealer and show them what is wrong and tell them to fix it right. Obviously, they changed something to make it use twice as much oil.
My main concern when my update was done this past summer was that it would not use enough oil. Took mine out for the first(and only) ride this season about 5 wks. ago and all seems well. Keeping my fingers crossed.
Let us know how things turn out.
Check to make sure the linkage is not dis-connected. Typically, the pump will go full open if this happens. Common issue on previous models when the short controll cable breaks.
Tim figured it out(thanks Chad)....oil pump arm got flipped over somehow..causing it to way over oil...
Yep, Thanks Chad, iqrider on here. I facebooked him to ask him only if he knew if a particular dealer would be open tomorrow. He asked what my problem was. I told him I was going through a ton of oil. He immediately suggested to verify that the arm hadn't flipped over center. Sure enough, it had. Sounds like he has seen a few of those including his own sled. The guy even helps riders out on Christmas day! Now my new head is on and that thing rocks! Cant wait to get it out on a hill tomorrow.
I had this same issue with my new to me sled. Was nice for it to be a simple fix! I guess its better for it to burn a bunch of oil when this happens as opposed to not enough...
Not for nothing, but 2 quarts in 10 gallons of gas or "a little of a quart" in 5 gallons isn't really that bad ratio wise in the real word.That comes out to 40:1 for the 1st case and about 35:1 for the second.
Doesn't seem that bad. Has the Pro spoiled people on their oil consumption this quickly?Quit frankly I wish my Pro used more oil.
uhm...2 qts in 10 gallons is 20 to 1..40 to 1 ratio is 1 qt per 10 gallons of fuel...
