EvolR air pressure
Boston Racing
What are you guys running for air pressure in the main chamber and the evol? I don't have the original setup sheet and want to get back to some kind of baseline.
I weight 220lbs
150ish evol and 85 ish is what I run on the front of my barkbuster set-up on my M with mesh hood /no air box etx..so my frt end is fairly lite...im 235 lbs..
from what ive read the lowest usually ends up being around 125 ish and 55ish
always air the evol chamber first..
hope this helps
my knob adjustment (rebound) is 11 clicks in from full out..
I tie a zip tie real tight on the shock tube and push it up often to see where it ends up after a series of different terrain to
see how much travel im using..
but I like my above setup..cushy ride and no bottoming with some spare travel for the unexpected
I weight 220lbs
Front or rear, Carl's kit or?
Carl's front starting point - 115 Evol, 60 main, rebound 7 out.
Carl's rear 160 Evol, 135 main, rebound 9 out. Plusher ride 160/120, rebound 11 out.
I run the fronts at 110/55, 8 out. Stab bar in. Rear depends on day, if I carry fuel, but generally 155/125, 10 out. I'm 210 geared up.
