I
IQRIDR
I have not noticed the weight either. Like I said before, the X1's are 2.5 lbs more on each side over the stock WE's. I figure about 1.0 heavier than the Fox Evol R on each side. My water bottle weighs that much.
I found this to be true. That's why I roll my eyes when people talk about the adjustability factors. Once my shocks are setup I ride the piss out of them. The one exception is going from the winter fluff to the spring concrete. I'll sometimes work on compression and/or rebound.
Roll your eyes? Let me explain then. Where I ride, the snow conditions from day to day, week to week, can vary from deep bottomless fluffy pow, to deep, concrete-heavy wet snow, to solid-base snow with freshies. The weather of coastal Alaska brings us so many different conditions all year long. So one day, we might be boondocking through the trees in a snowstorm, the next we might be riding slightly set up snow above treeline, dropping and jumping. My shock setup will vary each day depending what those conditions are.
When I had my stock WE shocks (sled is an '11 assault rmk) those changes would just be cranking the clicker or backing it off. Anywhere between click 2 and 16. Same with Exits.
When I went to the Evol R's, I bring my shock pump and am adjusting compression, rebound, and air pressure to meet the conditions each day before a ride. I might start the day on lower settings then go up 25 PSI and more compression and rebound when we start riding hard and hitting drops or jumps. It's not like just cranking a clicker sometimes to get it where you want it. And it's not one but 2 air chambers.
In this respect the Evols do require more fine tuning, no? But, they are what is on my sled right now for a reason
Just trying to better explain what I meant.
