H
happyhour
If the station is selling an ethanol blend, is it stated right on the pump? Basically wondering how to tell.
mtbe is now banned from fuel so most evey fuel blend has a perscent of ethanol in it as far as I Know that is why a while back texas had a big uproar about it and tried to reverse it but congress luckly shut it down and said you will run it, every place around here has it marked very clear on what percent they have but when you get out west I am not sure on that a 90% ethanol blend is not even realalistic for the back country simply because you would need to cary to much in with you to make a day of riding and as far as I know they do not even offer a 90% blend it tipicaly is transfered as 98% and then blended. in a high performance say the late model or a modified a 98% is best because it has a high octane rating the same with methanol just about identical on the dyno the methanol will tipically see a little more horse power than ethanol that is why you see methanol run more than ethanol in the dirt world every little bit hp will help you on the track as far as running a lower blend of ethanol be it 10 20 30 even50% the snowmobile world can benefit from it from a performance end .
