Do a towing search on both the new and the old snowest forum. This topic has been covered several times.
In flat dry conditions towing that kind of weight with an suv or 1/2t is marginal at best. Towing an enclosed 4 place with an suv or 1/2 ton in mountainous icy conditions is pure suicide.
For safe winter towing you are looking for a weight ratio of 80/20% tow vehicle vs trlr weight, and at max a 60/40% ratio. It is as simple as that.
Its a recipe for disaster if the trlr weighs more than the tow vehicle or any where near it.
Personally I use a 1ton crew dually 4x4 to tow a 2 place aluminum trlr with two more sleds on the truck. Thats about an 80/20% ratio. Drives like a dream on ice, no more white knuckle driving for me.
He posted the same lame info in another thread like this one. He didn't believe me when I pointed out the same thing.....Your math doesn't work, example.. 2006 Mega Cab ram (1 ton dually)- 6500lbs curb weight with 80% being the truck you could tow.. what? 1600lbs? That's 1 sled on an open trailer... now with 60% being truck... Your sitting at 4500lbs you can tow.. so say a 2 place enclosed tends to be in the 2500-2800 mark, add 2 sleds, your done.
So with say a 4 place running at about say 3600lbs.. 4 sleds at say 800lbs each... and we're talking dry wieghts here... You'd need a truck that wieghs in at over 9600LBS based off 60% being truck. 80% you'd need a truck that wieghs 21,600LBS to pull a trailer with a wieght os 6800lbs...
I wouldn't even think of towing that with a half ton let alone a gas truck. You should be towing that with a diesel 3/4 ton. Hopefully you never get into a dicy situation where you need more power, especially while in 4 wheel drive towing. Its not just the weight but also the amount of air you are pushing with a trailer that big.
I've got a 5.3 Yukon and have been debating whether a 2 place enclosed will be too much. I wouldn't even think of pulling a 4 place not only for the reasons mentioned above but also because I'd be affraid of smoking the tranny and rattling the engine too much.
IMO it would be a red line, white kuckle experience.
Your drivetrain will be absolutely fine with a 2 place enclosed under 5K.
