engine tech billet 900 top end for the m7, has anyone ever turbocharged them? any luck with it and wich system? thanks..
A 53 is small for a 900, but I think you could get away with 6 pounds of boost for a pump gas setup with a 53. I played around with one on an 800 without issue.
As far as the M7. If you ran an EGT, a BD Box, your ECU and regulator, you could easily run a larger Aero with a secondary fuel pump. Just keep the little $100 pumps on hand. Because you will need a new one about every 300-500 miles due to the voltage fluctuations. There are other options on the pump. I just dont suggest them and they are too much $ for what they do for you.
BB
when I ran that set up I ran an aem 02 and a second fuel pump and a PL controller and smoked my stator
