Thanks for all the help
The easiest way to get at the bleed screw is to remove the exhaust pipe, and the intake plenum, then you will be able to get a screwdriver at it.
As far as the oil goes.... its a judgement call on your part.
Just imagine...... if your oil pump gets air-locked on your first ride... the only oil she's going to get is from what you mix the tank at. I mix my first tank after an engine installation at about 50/1 but I only fill it half full. Bring spare spark plugs!
I also R&I'd my engine this summer and replaced the mounts and of course cleaned and maintained everything....as im completing the final installation at this point I have noticed there a couple of noticable bubbles next to the connection by the crank seal. ( i have bled the engine from the bleed screw already)you guys recommend popping that line loose and trying to bleed it out or is it just no thing for that particular line in the big picture
? ( The coat hangar trick is cool and i will use it!)(will also premix)
Also my main man rmk 2112 gave me a (polzinhunter chaincase cover??) and i will be installing that, you guys that have one , what torque spec do you reccomend to seat the rubber gasket properly. Thanks in advance.
