the bravo has a catch and return system for the oil and gas when sled is overturned...they sure could incorperate that easy
I have found a different solution to the catch can. There is a kit that includes a tether and shut off valve. If the tether is pulled, the engine will quit, and the valve on the oil tank breather line will close. The valve is fail open in case there is some kind of failure in the system. When the valve is closed, a LED comes on. This will also be handy in those cases where you want to roll your sled over to get it unstuck. Just turn the key to the run position, and pull the tether to close the valve. I have attached a picture of the kit. It looks like a really nice install.
I wanted a tether as a safety device anyway, so I thought I'd give this a try. $149.
http://fourstrokesolutionsllc.webs.com/
Thats my set-up!
The main advange to wearing a tether. Is if you roll the sled over and the throttle gets pinned (it's happened to me before), the motor gets shut down right away.
This is important because the positive crankcase pressure from a operating engine, will pump oil out the breather vent very quickly. Faster then if it drains out from gravity flow alone.
I have a pressure/vacuum guage installed on my Nytro to monitor oil tank pressure. I used it while I was designing the system. It's true that the breather needs to vent both negitive and positive pressure (vent both ways). However I was suprised to see how rapidly positive pressure would build up at idle, when I pinched the vent line even for just a few seconds! This is why guys will loose more oil when the engine is idling, then when shut down.
Some guys have the roll-over oil valve system, and don't wear the tether. The difference is you just have to reach over and pull the cord, if you happen to stuff it in a tree well!
I use it "manually" for anytime I want to roll the sled on it's side, ie getting un-stuck, inspecting the bottom of the sled, making suspension adjustments, etc
AA I'm interested. Keep us posted.
