J
Jerseyrider
Guys,
Doing my first complete engine install and need some advice. Is it better to but the pistons, cylinders, and head on before dropping the engine in or drop the engine in and then put the pistons, cylinders and head on?
Bought the 900 with the engine out, cylinders and pistons off and primary clutch and stator on. Have replaced cylinders, pistons, clutches, and throttle bodies in the past but never had the engine out. Was thinking it might be easier to connect the main water inlet hose with the cylinders off but then realize might be a tight fit to tighten the cylinder and head bolts (the ones in the back) once the engine is in.
Any other advice or tips would be great.
