N
nuttyn01
Alot of variables invlolved. I couldnt run 12.5 pilots at 6000' on my sled without 1/2 choke. I ended up with 17.5 pilots. Things like charge tube size, type of reed petal, fuel pressure, where you are pulling signals, type of pipe, etc. all play into the tune of the sled. I personally have a cpi pipe. I wouldnt be afraid to try 17.5 pilots if it feels lean.
What are the symptoms or how do you know its leaking? What does a leaking base gasket do? We are trying to figure why are tuning is so different from others. My brothers turbo xp won't idle and he has 15 pilots and its way lean. The A/F is pegged to the right and will start to come down if we pull the choke on slightly. The bottom end is so lean that its got run-on really bad and you have to pull the choke to get it to come down. We are going to try 17.5 pilots but wondering why other are running 12.5 and 10 and we are at 17. Maybe a leaky base gasket? It runs great 1/4 to WOT, just won't idle and lean until 1/4 throttle. Thinking of maybe air leak somewhere, or maybe its the CPI pipe idles different, or the RK tek pistons he has in it?
