Enclosed trailer what to look for?
So I'm looking at getting my first enclosed trailer. And I'm wondering what to look for in either new or used trailers? When talking to a seller what types of questions should I be asking? I'm on a bit of a budget, but don't want to just buy anything. I will mostly be hauling my 2 sleds so what size would you recommend? So any help would be great.
If you are on a tight budget, I'd make sure you get a trailer that is 7' 6" tall just in case you ever want to put a side by side in there and at least 8' wide (preferably 8' 6"). Insulation, aluminum wheels, furnace, etc. can be added by you down the road as your budget loosens up a bit. Don't get sucked into the Steel vs. Alum debate. People have very strong opinions about steel vs. alum (it's almost like a religion). In reality there are good and poorly manufactured brands of both types. If you really want to know what will hold up, check out the trailers at the parking lots and ask their owners what they think of them. Ask how old they are and how much/hard they've been used, then you can determine what brand handles the extreme conditions of winter towing the best.
I have an 08 25' Interstate enclosed trailer. 20,000 plus miles been thru hell and back! Still looks great and everything works like new! Yes I do my up keep on it and fix and service when needed. It is steel frame and with the customer service from the Interstate factory would not buy another brand. JMO Good luck in your search hope this helps!
I just sold my 2013 Cargomate Snowbird 3 place trailer that was built very cheap. It had so many issues that I had to take it back to the factory for warranty and pick it up on my own dime. :mmph:
When looking at a used trailer I check the date code on the tires , check to see when the wheel bearings were repacked and also when the brakes were last inspected.
Also I check the tires for abnormal wear and look at the frame/suspension.
I have a blizzard 14'+4'v that is under 2000lb, can hold 3 long tracks being 101'' wide and can easily be towed with a gas pickup, easy to move around, a little over 6' high inside so I can walk around yet low enough so it is not to high in the wind for towing, vey well built. it suits my needs perfectly.
