Mine still ran fine from idle up to the mid and then fall right off. Here is some stuff I found here on DooTalk lastnight while I was searching through the forem for information.
[I]Very easy open up the left side panel of the sled and its a square looking plug with a mounting tab on the end of it, right above your secondary in the harness it just unplugs, your best bet is to go to Napa and get a couple of them, Part # AR 201 there about $12 compared to buying a skidoo one for $25.
Well you guys were right - $13.19 @ the local NAPA & we're back in business!! It was Part #AR 272 though - not AR 201. Anyway, it sure beats the s**t out of what the dealers would charge for the repair!! Thanks everybody
AR272
Features & Benefits:N.O. Terminals 30-87 @ 30 Amps; N.C. Terminals 30-87a @ 20 Amps; Coil Terminals 85-86
# of Terminals:5
AR201
Features & Benefits:N.O. Terminals 30-87 @ 50 Amps; N.C. Terminals 30-87a @ 20 Amps; Coil Terminals 85-86
# of Terminals:5
The AR 201 works just fine, have one in my '03 in fact (50 amp rated) but costs more. If you want an exact match to the BRP unit then get AR143 20 amp rated. The AR272 is rated in the middle at 30 amps and priced accordingly. All three will work but I would just buy the cheaper AR143 for spares
Part # 0-332-019-150 for bosch relay [/I]
I hope this helps
