i believe he's referring to the altimeter that is built into the EBC controller. give BD a call and see what they have to reccomend on the subject 877-522-7805
Sounds like your caibration is off. Pretty sure the installation instructions tells you how to recalibrate it, they are on boondockers website if you don't have it.
95RXL, I didn't install the altimeter, it is the stock gauge, you can select it by scrolling through with the mode and set switch on the left handlebar controls.
Right. I was able to find it on my display too before I bought the actual part that you need to plug into your wire harness. It just didn't work until I had the part.
I'll try to find the part number for you if you want one. There's also an air temp sensor if you want that on your display too.
Here it is:
2875125 Altitude $69.99
2875126 Air temp $39.99
