electronics capacity on 800 dragon
KJAssault
hey guys got a question about running gauges on a 2010 polaris rmk 800?
got a pump gas boondockers kit. wondering what I can run for gauges with it without messing something up.
electric stats on the kit
oil pump
intake fan
boondocker box (for now)
EBC
Guages want to add
Digital AFR
analog boost
koso dual egt
also were do I get power from under hood?
sled has headlight delete, led tail light.
any help is greatly appreciated.
I tried to find a spec on the system, and can't find it (yet). I'd guess you'll have no trouble powering everything you want to install, especially with the headlight delete. I've got the same turbo kit, with a Digitron exhaust gauge. No troubles, although I do have the electric start (and battery obviously). The hand and thumb warmers don't seem any less powerful or quick to heat, and that is where I've noticed issues on my other non es sleds. I have watched the volt meter in the mfd, and it's always at or near the top. Hope that helps!
best place for power would be the accessory plug (wrapped under your console on your steering post) that your oil pump should be plugged into, easy to tee off of that to power a few accessories. not running the head lights you actually want some gauges to help take some load. i ran bd box, egts, oil pump, lighted boost gauge, and the stock headlights for 2 seasons on my first d8 turbo build with no issues
