Hopefully it dumps it in during WFO throttle after any break in parameters are met. The peeps I know that really ride the etecs use as much fuel and oil as my turned up fuel and oiled Pro.
Why not quit building motors that need a pump to oil the bearings and go premix, one less thing to go wrong and blow up your sled and would save weight.
When I spoke to the Polaris engineers about this, I believe the break in time was 20 hours (that number is in my head but that seems like a long time). It injects more oil and the mapping on it is not just based off of RPM. The old system was only RPM based (it was a physical pump so it could only take input from engine speed) The new system is 3D, meaning it will take a variety of readings and inject, adjust accordingly. RPM, engine load, throttle request/input, engine temps. 8100 rpms on a flat trail is not the same as a full throttle pull up the side of the hill with 4 feet of powder.
The engine break in period can also be reset by a Polaris dealer through the computer (digital wrench or whatever it is called). So if you do a rebuild you can re-do the break in period as well.
This will be better yet.
