Electrical question
I have a 2006 Summit 800X. I removed the electric starter because it was not working. Now the problem I am having is the lights & tachometer do not work. I put the ground wire back on that was located down by the atarter. All I did then was remove the battery bracket that was by the chaincase. I unplugged the solenoid (2 things to unplug) and then zip tied all the wires that came off the top of the battery bracket together and tucked them back towords the motor. Those wires are still connected to whatever they go to. The sled does start by pulling it now because a relay was changed. Does anyone have any possible ideas on what I did to cause the lights and tach to not work? Thanks.
Delo
I am not sure if this is needed information or not. But it was running fine after the relay was switched out. Went riding once after the batter was pulled and all was good. All I did was unbolt everything. It is almost like it is a fuse. But I was onlly able to find 3 fuses, and they were all good. One right about where the battery sat and 2 above the clutches. Thanks.
Delo
I'm seeing this same issue, anyone know what it is. Everything works good with the electric start harness plugged in and battery hooked up. When I undo my battery and plug in a manual start harness with the same relay as before, no headlights and no tach.
