So I have found the Root of the problem.
I found that I indeed had voltage, but no amps to the MFD. But I did have amps to my aux power. Running the MFD alone off AUX worked fine, so I started tracing out where my power was going in my hood connector. On Accident I left hood connector #2 disconnected and my MFD started working (lucky right there), connector #2 only has 5 wires, so I connected each one at a time till the MFD turned off... and it was the speed Sensor, shorted out that was causing my issue. Remember in Post #1 there was a sound??? digging into the speed sensor I found the Jack Shaft Bearing was exploded which is the root of the real problem...
And to think I was about to head out this weekend with no MFD cuz everything seemed fine.
Now the real bad news... I have 2 sleds mostly tore apart needing to go back together, when all along the issue was right behind 5 bolts with pretty easy access.
Thanks for all the advice,
Keith
Good, thanks for posting findings.
