P
pura vida
ok, so i need some advise and help from all you experts out there... the sled is an 07 600 rmk. i am having some electrical issues i can't figure out. my headlight is dim (basically not on), my gauges will reset now and then when idling, and my kill switch rarely works. and the brake indicator light on the dash stays on most of the time. but there has never been any runablity issues, just annoying electrical junk. i had the sled completely pulled down this summer/fall and check all of the wires for cracks/rubs/breaks. there were none. all my grounds are good. could this be a voltage regulator? stator? i would think if it was a stator it wouldn't run good? any other ideas? i thought the kill switch was separate but i replaced it and check the continuity and it seems to be fine, at the switch anyway? the biggest frustration is it isn't always consistent. sometimes all of these issues go away (but always come back) but i'm afraid it is eventually going to take out my ecu or stater which both are expensive. thanks for the help as always.
pv
pv
