Electric start rotating mass?
You will like your ES and will not notice and rotating mass difference. I have had ES on last 4 sleds. It will help your shoulder out tremedesly and makes for starting the sled much easier when it is in an off angle situations. The shot system is definitely sweet on the DOO. As mentioned by other people, just get a lighter/smaller battery and put a different muffler on and the weight will be a wash. I sure do enjoy turning the key after an adult beverage on top of a mountain instead of pulling that stupid cord. LOL
I couldn't stand it and sold it. It is definately a heavy option for Polaris and you will feel the sled being nose heavy.
This is funny.
I never heard anyone complain about the Axys being nose heavy due to ES regardless if they were NA or not.
Did the Matrix really gain 40 lbs?
This is funny.
It did gain about 5 and another 30 if you want E-Start. All in front by the motor. This plus the heat exchanges up front more shifts the weight forward.
Agree, could feel my 800axys was nose heavy with ES compared to my 850 pull start.
New matryx will be pull.
It’s a complex answer but the short answer is what the battery does and how much it helps with this phenomenon. If you’ve spent any time around Polaris forums, I’m sure you’ve heard our forum experts whine about TPS issues. TPS or potentiometers are very delicate and sensitive to electrical noise. I first learned about this with early Cummins diesels popping TPS’ for lunch in early 2000’s. After I dug deep into electrical theory trying to prevent customers from keeping 2-3 new OEM TPS’ in their glove box, I learned about electrical noise. What I was seeing back then was TPS voltage sensitivity feeding back erroneous voltage signals to control modules. Remembering those years, I did some of my own testing on a couple of non ES Polaris’ that I was chasing TPS issues with filters. Then tested my own sled that was ES. The results were astonishing. It was just easier to solve with ES. My buddies have all have ES ever since.
There is always electrical noise in any system, the question is, is the noise acceptable? And it’s a balance between too noisy and trying to design by filtering too much. Filtering too much can be a negative. The battery quickly and easily solves this.
Polaris has done a much better job in recent years with some subtle changes and contrary to the forum experts, they do read these forums and listen. ? I still think the battery is the true fix. IMO, Polaris should add it to all sleds. I’m sure the 3%er forum experts would disagree and lose their minds. You see it with every take off ES kit for sale that doesn’t include the clutch.
If you want to better understand the phenomenon, this link does a pretty good job of explaining it.
You could add a 12oz battery to act as the filter rather than the entire system and save some weight. Should start first pull since capacitor would charge without a pull also.
I’m not worried about being nose heavy, I’ve never felt a weight difference between say a stock can and a 10-lb. lighter one for example. I was more concerned about rotating mass as regards throttle response.
10-20 lbs. of starter and battery can easily be compensated for with suspension adjustment.
Never thought the kaos matryx with e start was nose heavy. Guessing you could probably feel the e start weight if you rode them back to back but that doesn't make them nose heavy. It just makes one heavier than the other. Also guessing you are not going to feel some big difference in rotating weight. There is no one big thing anymore. It is a lot of little things to add up to something
I have no idea where people think that a heavier clutch means longer life, that is just not true...A heavier clutch is harder on the crank than a lighter clutch..the inertia of the clutch effects the crank!!! start and stop anything that is heavier and tell me it is easier on the part...If you want to discuss a crank damper, what entails that? a softer material to absorb the harmonics, a ring gear will not do that...I can promise you by taking the starter gear off you could feel the difference in acceleration!!! if you worried about pulling to recoil then leave it on..
I agree with you but where the loss of mass allows for harmonics then lightening could be a problem. Obviously this is not true for the motors were are talking about because the manufactures sell the exact same product with and without the ring gear. I definately would not like to try running one of these motors with no clutch on.
Poo would have to have a new DI engine to have any chance at a shot system. Ordered a 23 doo just for shot. The poo e/s stinks and the battery/ tray is beside the beltdrive so more stuff to mess around with for a belt change.
Where is the battery located then? Or is it still beside the belt drive but a lot easier to remove?
Most of us wish we were so good to make use of the reduced rotational mass, or rode in hip deep pow so often that it's truly helpful - is it real - sure was on race clutches. But, we're not racing.
Most of us are just not at that level, never will be, and don't ride in terrain or pow often enough to take advantage of the spin up. We don't have the talent, or don't have the throttle time in pow to get that skillset. Something else will hold us back, and lack of rider conditioning is generally the biggest. Nothing wrong with balancing. Cole/CVC's bat and tray are a huge weight reducer. E-start motor and ring is still there, and even if the weight bias is better, and it is, we can't tell. Just living in Realville, not Disney or Fakebook. Look in the f'ing mirror. For most of us over 25, gym and cardio will give us the biggest gains and longest days.
Do you think putting the lighter battery kit on, lessens the effect the es system has on electrical noise ??
What are you like 70+ years old 350+ lbs and totally given up? Try to push harder, the rewards are very real.
