Electric start Clutch adjsutment
RanOutofTalent
I added an electric start to the wife's 2020 Axys 800 and it works well. But when I rode it today I noticed it was over revving really easily up to 8500-8600 RPM and the sled would act funny if I full pinned it, kinda like it wanted to cut out. Is this from now having the correct amount of weight in the primary?
When I installed the kit I put the old clutch weights in that I believe were 10-66 as we ride mainly 6-9k. I will need to take it off and check it out this week to be sure.
If the weights are at 10-66 is there anything else I should be looking for to solve the issue?
This was a brand new ES kit from the dealer. Sled only has 350 miles on it.
Thanks
  • 2 Stars
Reactions: TRS
Absolutely nothing to do with ES.
Well it does have something to do with the clutch as when you buy an ES it comes with an entirely new primary with the ringgear attached. As my post said I may have the wrong weights but as I can't get to the sled for 3-4 days I was trying to see if I was missing something.
Probably safe to assume you have the wrong weights in there.
Unless it’s a different spring?
If you put the cover on turned 60 degrees it would bind and give low rpm.
Same with a bad roller.
Thanks. That is solid advice. All things I'll check tomorrow when I am able.
Did you properly clean the primary clutch? They can have machining oil etc. left on them, I cleaned mine with brake cleaner on a cloth and scuffed it up a bit with scotchbrite (like you would to remove belt residue) and the same clutching from my stock clutch worked great... Clutch ALIGNMENT was off however not enough to make it behave badly, seems the estart primary can have a different offset (.170 in my case).
I had 10-66s in there and swapped them out for 10-68s. Rpms down to a consistent 8150
Still a little room for improvement.
