P
powerfuldodge
Just wondering if guys with turboed sleds are running EGT guages. ![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I don't know of any AFR probes that can be cleaned without damaging the sensor. One thing though, is that with the newer emissions regs for sleds, they are cleaner running, and therefore don't seem to foul the sensors quite so bad as just a few years ago. Initially, you may go through a sensor or two, trying to get the sled dialed in, but once you have everyhting set up properly (Fuel, Oil, Etc.), you shouldn't foul often at all. Hopefully this helps. Not trying to steer you one way or the other. I personally use both (not on the same sled) and find either very helpful.I clean my clutch faces every trip can you just clean the probe for the AFR so it doesn't get fouled?
EGT helps you to monitor the temp in your cylinder. Without one you tuning blind and you run the risk of burning your sled down. AFR is an added beni to the EGT for fine tuning.
Really....................... I have not used a egt for 5 years started using o2 on turbo sleds. Lost one set of pistons in that time and the o2 gauge told me they were going to bake. It is a mater of personal prefrance
Thats what I ws wondering. This will be my first turboed sled , so just watch your air /fuel gauge to see where your at. What is the ratio most people shoot for?
I do love boost, run 65PSI of it in my truck.It depends what it is but around 12.3 is usaly safe for a 2-smoke.
A af gauge will not tell ya if your cylinders are burning even, it sometimes glichy and defiantly not as reliable as a egt, will not give a accurate reading if your sled has the slightest of sputers. What it does do it does well, there fast and accurate, you can actually see the fuel mixture go rich 1/4 a second after you pin it. You can get a really good feel for your sled and not even need any gauge after having one. Again it is a choice and preference.
Your going to love boost, it is cool.................unless you have to much of it
ya buddy you and me both! BTW how do you like the 6.7L cummins? Have you had a 5.9L in the past?
