Who out there is running a egt gauge on their Turbo Nytros? I am having a hard time tuning it. A few of my riding partners say put an egt on it. I all ready have a A/F. why would the turbo kits not come with an egt gauge? any help
Egt's are worthless. Your wideband a/f gauge will give you way more accuracy. The problem is when your poping on top end you a/f gauge isn't going to read properly. I would do a boost leak test and change your plugs. If that doesn't work your going to have to do some re-mapping on your rb3 (I would assume you have if it's a pl kit). I would first add fuel on the top end to make sure it's not a lean pop. If it continues to miss after adding fuel you can know it is and was a rich miss so then you would start pulling fuel on the top end. You also want to make sure you have enough cam arm weight, if you don't it will hit rev limiter and pop on top end as well.
Have you actually pressurized your intake system up to 20 psi to make sure there are not boost leaks? Not just a eyeball test? What fuel control do you have?
I forgot to ask if it has worked properly in the past? If so, I assume your A/F was good? Any boost leaks?
