What is function of EGR sensor? Is it tied to computer for fuel control?
The Polaris sensor in the big part of the pipe is an EGT sensor. It feeds input to the ECU.
Pretty much all cars these days have an EGR valve of some sort.
I never said it did. I just said the stock sensor was there to give the ECU feedback.The stock pipe sensor is not adjustable nor does it give you feedback on exhaust gas temps. It just blinks 5 times when the $hit hits the fan.
If you keep the stock head, pipe and fueling an EGT won't do anything.
I added EGT's when I boosted. That said, on my 08 D8 I can watch the EGT's and see the mid range lean spot that takes down some of the 800 cfi's. On my sled even with aftermarket fuel control (Boondockers) I can see temps exceed 1350 if I hold the rpm's in the 6800 - 7300 range or so.
All I have to do to bring down temps is wick the throttle a time or two and/or vary the rpm range. I think egt's on a stock sled would still allow the rider to spot and ride around the potential lean spot that some of these sleds seem to suffer from. Some seem to think this condition can be increased on hard pulls after the fuel in the tank drops below 1/2. If that is true you would see that on egt's as well. Just a thought. EW
