Is the stator able to keep the battery charged?
you need to Boost reference the float bowls. This was the fuel gets pushed in. Also, what size pipe do you have going from the pipe to the turbo? should be 2" no bigger
I took off the turbo because I was going for a long trip last weekend,
and it had not been tested enough for longer trips yet,
I'll install it again and add voltmeter and fuel pressure gauges to see what happens to my fuel, think the bowls got empty on long pulls.
Yes I added the battery, and a 50A rectifier that goes to the battery with it's own ground, I do not use the chassis for DC ground.
I have been using it the whole season for powering my gps.
My battery melted on the side facing the pipe on the long trip last weekend,
so guess I need a heat shield and a new battery.
Did you enlarge the fuel tank vent?
