I've got an 02 700 144 w/SLP single, 18/41 gears, 10-66 weights, almond spring and a TSS-98 with a 58/42-46 helix with black/red spring. I ride 0-4000 in Alaska. A friend gave me some 10-64 weights and a 62/40-46 helix. Would it be worthwhile to use these weights and helix or am I better off with what I have? I plan on putting on the black/purple spring.
Thanks a lot for the advice. I am only seeing about 7600 on long pulls. I'll give the 10-64 weights a try. Should I keep the almond spring? I was also considering the polaris black/green primary spring with the 120-340 rate. That would give me a slightly lower engagement speed and maybe a few more RPMs on top.
I'll let you know how the 62/40-46 helix works out.
ps. hard to beat Lost Lake on a good day..
I just posted a 43t bottom gear for sale in swapmeet...
I run slp springs in my primarys. I like the green/pinks. They engage alittle higher, yet don't just slam in like alot of high engaging engines do. Even tough they engage high, you can still really feather your take off so you don't trench when needed. This really wakes up the bottomend. The 64's should give you your r's back. The 800's pull 66's. My boy rides a 7, and the wife and I both ride 800's. All are currently running twins, but did all have slp singles at one time. I also help setup sevral freinds sleds both 7's and 8's. Let me know how that 62/40 works for you. I would love to try one. Once again, by going to the 62, I am thinking that you really want to put that slp green/pink in the primary to help pull that angle. It should rip set up like that. Make sure to put delrin washer in your secondary while you have it open if there are not aready some in there.
Thanks for the recommendation Ultra. The 62/40 helix with the black/purple feels like it won't give up on the hills. I ended up going down to 62's to get the RPM's up in the 8100-8200 range. The green/pink primary has a great light feel to it on the bottom end.
Now with my gearing and clutching all set the last thing I did was take off the boost bottle (waste of money). I also sent my perc CDI in to PRO-5 Racing to get reprogrammed for a 14 degree flywheel. These two changes made my engine idle a lot smoother and gave it a totally different kind of crackly sound like a more radically piped engine than it is. That was one of the best things I've done. This old 700 feels like a sports car now.
Now to burn as much gas as I can before the snow melts....
