F
fast8seccamaro
I got my jaws pipe back from getting ceramic coated and installed it on the sled with the temp sensor. When I started the sled I got a ECM code 17. I visually inspected both connectors and used a ohm meter on the sensor and seen about 200ohm and when I used a small torch to heat the sensor it climbed over 300ohm before I stopped, I would think the sensor is alright! Where should I be checking next? The wires at the ECM to make sure the wires going thru the sled and the connector is actually good? Anyone have a pin diagram for the ECM connectors?
