ECU 14 Flashing
Had ECU 14 flash on my 2012 today. Shut the sled off and restarted and went away for about an hour then came back on. This would happen about 5 different times. The code on the clutch guard said ISC Actuator. Does anyone know what that is and what I can look for to fix? Or is it a dealer issue?
Thanks for the meaning of ICS, but was wondering how to fix and where it is located or what to look for.
I would guess that it is the selonoid looking valve on the bottom side of the throttle body. It is on the bottom right side as your sitting on the sled. Kinda hard to get at. I just had mine unplugged when I did my head studs. Have you had any work done? Maybe it is unplugged. If you have not had work done I would take it to the dealer. But a quick look to see if it is unhooked would be easy.
Same here. I forgot to put the connection back when I did my headstuds. If you get a hold of a small-handed person, the connection is reachable with just the hood of.
