EBC wiring
W
wrang
New member
Hello. Have a 2011 HCR BD PG with intercooler.
It's two contacts I don't know where to put. (See photos)
Both contacts are in the harness that connects to the control box
It doesn't run well when I hit full throttle, it's acting just the same as a very cold 2-stroke engine.
And I don't get MAX TEMP in my control box, just 00.
Help Please
you need to hook one of those to the temp sensor in the airbox. It's a blue plug. The other side of that plug(blue plug, ecu side) needs a resistor that was supplied by boondocker in a bag labeled ADA.
The problem is that I didn't get the resistor. If I plug this contact in the airbox temp sensor (the blue plug). I still don't get the Air Temp in my control box. And ECU code 5 (Because I don't have the resistor).
