Is a 2010 M8
I'm running EGT's, Oil Pump and IC Fan split off of the power at the front harness.
The EBC flashes and dims at idle. I just went down to look over connectors, ground, worn wires and ran the sled. At 3-3.5K RPM for about 8-10 seconds; the screen would lite up normally and dim again instantly when the throttle was let off. I did this sequence about 10 times all with the same outcome. 1 time during this sequence the control box set itself back to the initial screen. The other times it had no affect on the control box.
it ran fine for about an hour today, then just switched instantly during my last pull, of roughly 20. I was dialing in the waste gate selonoid/actuator as it was over boosting.
