Good to know, a good amount different in steering effort then? Or is it a small amount? I tried laydown but just can't do it haha once I got used to the straight up post it's the way for me it seems nowJust makes it closer to earlier geometry of front spindle like the 12-15s and trail sleds have. TKI uppers with Riot spindles do same thing. I have that setup on my 1000 Ascender and it feels a little easier to steer than my 2016 Proclimb but it also has laydown steering eliminating another pivot point.
Yeah the laydown was already on sled and to fit the 1000 SLP pipe it made it easier without more damage to pipe. Got used to it. I do feel more at home on my other sleds with the straight up post. Not sure if the steering effort difference would be worth it for the money but the raised bulkhead with taller spindles and changes to the rear skid to match seemed to make deep snow handling better.Good to know, a good amount different in steering effort then? Or is it a small amount? I tried laydown but just can't do it haha once I got used to the straight up post it's the way for me it seems now
Mine moves pretty freely. one of my tie rods scrubs the inside of the bulkhead at one point though, maybe check yours. The rubber boots also create some drag.If you put one of the Cats up on a stand and move the handlebars it takes much more effort than it should to move the skis with no load. So some of the hard steering is just the poor design of the system.
The TKI arms do not have exactly the same geometry as the Ice Age arms but create better steering geometry. I have a set of the TKI arms in stock in Southern Alberta. Riot spindles and you get a similar effect as an entire elevate kit + arms.Good to know, a good amount different in steering effort then? Or is it a small amount? I tried laydown but just can't do it haha once I got used to the straight up post it's the way for me it seems now
I find when the sled is on a stand the steering is very easy to move. Maybe you have something binding somewhere? I can put one finger one the end of the handle bar and move stop to stop with very little effort.I see now the ski dampers are different part numbers! The older ones were superceded and I just assumed it was to the current model number. They look the same...curious what the actual difference is now. SLP sells the same one for all years proclimb through ascender to use with their skis.
Maybe. I made the observation when I changed out the pitman arm running down the spar to the bottom of the bulkhead. I sanded the paint off of both post bushing surfaces to try and free it up, but didn't remedy it entirely. Maybe it just had a real tight ball joint on the bottom of that new pitman arm?I find when the sled is on a stand the steering is very easy to move. Maybe you have something binding somewhere? I can put one finger one the end of the handle bar and move stop to stop with very little effort.
