Thought I would share some info in a different thread for the 800R.
I put some of this in the 860R thread but the 800 info I thought I'd put here to keep things simple.
800R Aaen pipe Thing can & Rad valves
I needed a pipe to run on this 07 last winter as the pipe was smashed and didn't have time to mess with it. Bought the sled for the new reman motor it had anyway and was going to big bore it. Reeds were shot so installed the RAD valves. Ran good in the sled, little funky on the bottom end. Pipe pressure was spot on with the stock size outlet on the pipe ( turns out it was the same I had for the series 3 860 which is what I bought the pipe for years ago), and outlet on can sized to match. Bear in mind the Aaen pipe was for series 3 800HO which doesn't run near the port timing as the R motor but------
I was happy with the pull, nice flat graph and it showed 154hp. This was with stock 470 mains dpm hooked up. Jetting was close to perfect, just under 1200* and the plugs showed the match. Pulled the pipe & can off and put on a borrowed a stock 07' pipe & can on. Still 470 mains.
Made another pull next morning and right off noticed motor was wayyyy happier. I figured the motor might make 142 hp +- stock on my dyno from past experience because it's pretty stingy on the #'s compared to what you read & hear.
Surprise! Sucker did 156hp with an even better graph. I was amazed!! Dyno showed it was a little fat, maybe even 2 or 3 sizes.
Peaked at 8,200 but it fell off really slow to 8,300.
I've never had a motor make advertized power before. Re-checked all my data and everything was on the money.
I've heard the RAD valves will add maybe a couple, but I'm going to be curious if I find anything different when I pull it down to blueprint for the 860.
Next, changed out the harness to 05' Summit with MPEM to get away from all the electronic BS. Will make some pulls and adjust timing to get the results and then I'll have a starting point for the 860R.
Fun Fun Fun!
Fun Fun Fun!
