All Polaris Pro/Rush 800 riders that notice loss of power as time goes on. We tested the 2012 800 new and about 150hp +or- 2hp and as time and miles go on they slowly loose their grunt. The BMP Durabilty kit is engineered and tested to correct the base design flaws of the 800.
There is 2 Flaws with the 800 that are fixed with this kit. 1st flaw is high skirt load with a short skirt piston. 2nd Under case volume(not enough).
The kit corrects flaw 1 by using a taller piston and a machined shim to give the high skirt load a bigger surface area which combined with a 2 ring Wossner piston (with wide ringland) makes the entire set-up a lot more consistent as time and miles go on.
The kit corrects flaw 2 by using a .250” shim inder the cylinder to help give a more suitable case volume.
The BMP Durabilty kit maintains stock port timing and compression meaning no fuel change need to run this kit
BMP 800 CFI POLARIS DURABILITY KIT $499.95
New Release Promotion price $449.95 use code durability
Pol 800 BMP Durability kit includes:
2 - Wossner piston kits (Piston, Rings, wrist pin, Circlips
8 – Cylinder bolts
2 – Base gaskets
1 – Shim
http://bikemanperformance.com/snowmobile/polaris/rush-800/bmp-800-cfi-polaris-durability-kit.html
Sled : 2012 Polaris Pro 800
Miles : 1826
Modifications : Stock = BLACK
Modifications : Stock with BMP Durability kit = RED
Adjustable Settings : Non-Ethanol Prem
Fuel : 91 octane Non-Ethanol
Dyno : Superflow 902
Dyno Operator : Joey Strub
8 – Cylinder bolts
2 – Base gaskets
1 – Shim
Miles : 1826
