If the stock Dyno sheet is accurate, holy crap. You gotta have your clutching dialed to nail peak hp. Wish the power band was a little more forgiving....
I can tell you that with the stock can Peak power is right close to 8000 RPMs when we put the titanium can on the sled it gains 200 to 300 RPMs...
So you're saying that with no clutching change you gain 300 RPM?
Also if I am reading your chart correctly the peak torque is 98.21 vs 98.86, a statistical tie. So the horse power increase is from a higher RPM not a gain in torque.
If you look closely at the charts it appears the torque and hp numbers were taken at the same rpm and the torque topped out at about 100 ftlbs a few rpm lower.
Something is goofy with that dyno sheet. 7900 to 8400 rpm the pro is within 2.5 hp from peak power. Pretty flat if you ask me.
