Ideally (and this a very gross generalization with room for a huge amount of debate) if you can get the motor to full shift and hold RPM with the heaviest weights and the tallest gears it will pull, then in theory you are running the optimum (efficient) setup from a clutching perspective.
In deep snow I think that is an impossible set up to get without extreme belt heat. I have found on my 800 mod that once I get further than a 1:1 ratio on big or multiple pulls up big stuff, the belt gets hot and performance goes bye-bye. So to make my life easier I shoot for 1:1 ratio with the biggest gearing that it will pull. I am giving up on some track speed and some distance up the hill but I can hit them multiple times or a really long pull without the belt gernading at the wrong time. Concrete snow maybe possible or the big power sleds that can ride up out of the snow? But I doubt even then the heat problem doesn't exist as the belt has to endure the forces in the secondary.
